Help please identifying old sea horse
ducedude
I recently got a old johnson sea horse. I know nothing about it and was wondering what hp/year it was? Also if i can still find parts and a manual for it? The serial # is 560700....Model 7020. Thanks for all responses!!!
bktheking
Re: Help please identifying old sea horse
Model number usually had letters on an "old seahorse"
ducedude
As far as I can see, 7020 is all thats there
bktheking
7020 is stamped on the plate on the transom clamp?
ducedude
Yes, along with the serial # 560700
ducedude
I looked again today, i was wrong on the model # it is td20....not 7020. Sorry, probably 1 to many beers last night :D
ducedude
Also was wondering the fuel mixture?
bktheking
Thought so, no worries:
1946-49 TD-20 5 hp
ducedude
Any idea's where i can get the following parts? coil, condensor, gas cap and the springs that go on the dogs on top of the flywheel? Thanks guys for all the info :)
tx1961whaler
That coil may still be good. It's the newer "Universal" coils that all go bad after 30 years or so
bktheking
He'll have to pull the flywheel, the early TD-20 coils were the horseshoe style coil which isn't the standard.
ducedude
I cleaned the carb, reset the points to .020 and cleaned them up and still have no spark on the bottom cyinder, so i figured the condensor/coil was bad
tx1961whaler
They could be bad; it's just not an automatic thing like on the later 1950's through 1960's coils. Those just go bad from sitting there and cracking.
bktheking
Swap the coils around, that will rule out a bad coil.
ducedude
I fixed the no spark issue, had a bad coil(found one on ebay cheap:)...All i need now a set of new springs that sit ontop of the dawgs of the flywheel...I've looked everywhere with no luck....Any idea where i might find these??? Thanks a bunch for all replies....you guys rule!
bktheking
Post a want ad in the webvertize portion of AOMCI.ORG, i've had great luck finding parts.
