b.gagnon
- Joined
- Apr 28, 2001
- 835
1979 Chrysler 70hp...
I rebuilt the carbs and changed the fuel pump.....Now when I try to adjust the carb it has no effect on the motor!
The best part of all is that the motor is running Great! In the water It is idling @650rpm in gear and smooth as can be. Top end is great too. The only problem is it is hard to get started (not sure if it had to do with some bad fuel that was left in the lines). Once it is started it will start right back up.
I set the needles to 1 turn out, and the choke is working.
What did I mess up!
What did I mess up!
