OldJohnson6hp
Thread starter- Joined
- Mar 19, 2009
- 53
Hi guys I'm stumped. My little 6 won't rev up to full rpm. When in neutral it will run up, runs excellent on slow speed, idles like a champ, starts in 1 maybe 2 pulls. I have cleaned the carb, water pump, ignition new etc..
It didn't do this before not sure what to do. Go to take off, put in forward, twist the grip and.....up to what seems about half speed more will not wind out to full rpm. Every one in a while it seems to want to go and you can hear the motor try to rev up. Also replaced bulb with a new one so it stays firm. Could it be the fuel pump? I disconnected it on the carb side, pulled it over and fuel seems to be getting pumped, but is it enough? Or maybe the float level off? I thought it was even with the bowl.
Any help much appreciated!
