Re: A few flooring questions...
Wow, thanks for all the posts and pictures. I drilled a hole in front and back, now I'm going to drill 3 holes on each side, great idea. Also the tank was foamed in when I ripped it out, should I foam it back in the way it was? And finally do u have any tips for glassing in the floor, how much u mix at a time, how big of sheets u cut out??? Thanks again.
No problem..My tank was not foamed in..I personally don't think its necessary. I would go over the bottom of your tank before putting it back in and epoxy any nicks or gouges in the tank...My tank sat on 3 heavy duty rubber strings that kept it from resting directly on the hull. And there were welded on tabs on the top of the tank that secured it to the stringers on the side of the tank.
As far as glassing in the deck. First seal up all the seams of the new wood with either PL construction adhesive or a 3m product such as 4200 or 5200. Give that time to cure and then run a strip of about 6-8" of 1.5 oz CSM on all the seams of the new wood first. I also, chose to tab in the sides of the hull to the new deck with first a 6" piece of CSM (3" up the hull-3" on the deck) and I ran another 8" piece the same way.
After that is when I covered all of it with big pieces of CSM. A suggestion, after the small strips cure, grind down the edges so that when you lay the bigger pieces over it, you don't see/feel the edges..makes a smooth transition.
I mixed up about 10=12 oz of Resin at a time and used a 3" inch cheap paint brush from Home Depot for the smaller jobs. I tried to calculate how much I would use per job, so I didn't waiste any, but it happens.
For the bigger pieces, I mixed up about 24oz of Resin at a time, and had a backup tub ready on standby by for hardener. I used a foam roller or a very short nap roller...don't use the real fuzzy rollers..they suck up to much resin and makes a mess. For the big jobs, make sure you have a back up roller as well, because the resin will start to cure on the roller.
Here are a few more pictures of me fiberglassing the deck.
Can't really tell..but in this picture, I have sealed up the seams with PL and layed a strip of glass over them..then will come the big pieces over it all. I drew in the tabs/strips I'm talking about.
Laying in a big piece....do yourself a favor and get a loooong handled roller to reach across the glass.
Resin on that big piece.
