nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,103
Ok, I'm going to try to start a new thread on this, because I really haven't been able to find out what's involved in resealing an outdrive. Mine's leaking, but a pressure test doesn't reveal a leak. Vacuum test shows leaking at the input seal (at least), but that shouldn't allow water in the drive unless there's water in the bellows. I'm guessing I have another leak that I can't find because of the input seal leak being bigger.
1. Can I split the drive, plug up the oil passage, and leak test each half separately?
2. Where are ALL the seals that need to be replaced for a complete job? (Pics attached)
3. What special tools are needed? Is this just disassembly, or does it involve shimming, setting preload, etc?
4. If there is a procedure somewhere in the adults only section, manual, etc, please point me to it!
