Re: swap 3.0 with 4.3
Rdobe99 I believe you are correcton the hp differences. When the 3.7 was out it was measured at the flywheel not the prop like they are today. So basically you can take away about 25-30hp to get a at the prop hp measurement. I would just try to find a donor boat with a good 3.0 to remove and drop in yours
This only applies to outboard motors. Outboards HP is measured at the prop because the engine and drive unit are connected and dont change they always have the same combo of power heade to drive unit.
Inboard and sterndrive engines are measured at the flywheel because the drive unit can change based on several factors and this will change the @prop Hp so they dont rate them with @prop HP because the engine manufacture dosnt know what ratio of the drive you are bolting it to, it could be a bravo, alpha Gen 1 or gen 2, it could be 1.81,1.91 or 1.94 ratio it could be a jet drive, or a surface drive. Point being every type of drive will have a differant Hp lose.
If you look at the specs of motors on Mercs website you will see that inboard and sterndrive engines have a HP rating but outboard have a @prop HP rating.
So with that said the best way to get the @prop HP of a sterndrive or inboard with out doing a hole lot of math is to figure a 10% reduction.
With all that aside the most important aspect of a marine engine is Torque not HP. Torque is what moves a boat witch is why diesel engine are the best marine motors.
HP is just a measurment of torque over a period of time and really isnt an acurate measurnment of power, its better to use watts.
