I have a 1976 15 hp Johnson that will run for about a minute and die, then I can restart it and it will do the same thing.
I tried pumping the primer bulb when it starts to die but that doesn't help and neither does choking it and I've noticed the plugs are wet after this.
The things I have done to the motor so far and hasn't changed a thing is this:
Rebuilt the fuel pump and carburator
Replaced the thermostat, one coil, points and condensors
Spark plugs I've tried champion UL81J's and B7HS's
Fuel mixture is 50:1
The tank is clean and the gas/oil mix is new, the primer bulb and fuel lines are also new.
The compression is 100 for each cyliinder.
Please help, i'm going broke trying to get it fixed.
Thanks, Johnson 76
Thanks, Johnson 76
