Hello I have a 70 hp 4 stroke Evinrude. The problem is after storage this year upon getting it home I raised the motor and unblocked it and then lowered it to check the oil. I had it serviced last spring and wanted to see if any oil was used. It was a quart over full. After setting for a while there was a small oily water mix that came out of the tilt/trim assembly. I lifted it up and lowered it and the mixture came out between the top and bottom sections where it is screwed together. I cannot find any place that help get the right answer for fixing the problem. Is there a gasket or does it need to be replaced?
Thank you for your time.
Gary
Gary
