eavega
Thread starter- Joined
- Apr 29, 2008
- 1,377
Hi guys
I have a good-running 50 HP evinrude that I took off of a small fiberglass tri-hull that was going to require a full deck/transom/stringer rebuild. I was intending to do the rebuild work, but before I lay out money for a rebuild, I was going to explore the possibility of just buying another hull. I've seen a few, but what I keep finding is that they are bigger than the boat I took this 50 HP off of, and all are rated maximum HP higher than 50 (I don't know what the original hull was rated for, since someone removed the capacity plate). My question: Is there a reliable rule-of-thumb for the smallest motor you can put on a boat based on its Max HP capacity? I've heard from different people you need bare minimum 50% of max HP to plane a properly trimmed boat, I've heard 70% will move you but won't break speed records. I won't needing the boat to have a lot of speed to it, since it will mostly be used for fishing or just slow cruising, but I also don't want to be underpowered to the point of just plowing through the water at less than 10 MPH. Any advice would be appreciated.
Rgds
-Eric
Rgds
-Eric
