82 Evinrude 50hp runs great all day at top, mid, and low rpm. It just won't idle. Seems to choke out at idle like it's getting too much fuel. Carbs freshly overhauled with new floats, gaskets, needle and seats. Float levels even with carb body. Timing is advancing, and retarding with throttle from stop to stop. Fresh fuel, new tank, hose, fuel pump, and primer bulb. 140psi both cylinders. New wiring harness on motor. Could reeds be bad, but run very stong at full/mid/lower speed? Ran it for 2 hours with no problems (other than it will choke out at idle (after about 1 minute)
Thanks for any help.
