bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
does anyone know a way to determine what comes in a carb kit?
i have not been able to find out what parts are in any KITS as the come from BRP.
I wasnt getting any gas into a 15 hp 4 stroke I picked up...
it would start if i squirted gas into the carb opening..
but it would die right away..
I had gas supplied to the barb on the side of the carb..so I figured there was blockage inside.
i took the carb off and started to dissasemble..
i dropped the bowl and eventually saw that the needle in the float seat wasnt falling free....it was stuck closed!!, there was no gas in the bowl at all!!!
so i found the blockage and felt that was the whole problem...but now i have to reassemble this carb...I didnt take it totally apart..and was thinking just the gaskets i took apart would be all i need...but there appears to be a missing check ball. that wasnt in the carb when i took it apart...
i figure it should be sitting in the bowl...it is #43
it doesnt appear to be captivated by anything other than the inside of the bowl!!
anyway, it isnt available..it seems..
I wonder if it is in the repair kit...id hate to pay $116 to find out it isnt in there..
what comes in this repair kit??
new jets, valve and seats? check balls?
does anyone know what dia ball it is??
i could just buy a ball bearing...
thanks
bob
thanks
bob
