solar7647
Thread starter- Joined
- Apr 23, 2009
- 1,218
I am wrapping up a rebuild of my engine, a 3.7L 180Hp Mer. and had a little issue today perhaps someone can better provide input on because I cant decide what the issue is.
A link to the rebuild thread if it helps any!
http://forums.iboats.com/showthread.php?t=384800
I filled the engine with fluid and hooked up the wire harness, Gauges and key switch. I hooked these up because I also re-built them and wanted the entire system hooked up and tested before installing into the boat.
I then connected a battery (the battery I used all last season). Once the battery was hooked up I turned the Key and turned the motor over with no spark plugs so that I could verify that there was no binding any place and to make sure everything spun freely. I also did this to help "prime" the oil system a little, since its that first start and I dont have any way to pressurize the oil system.
The key worked, gauges worked, and the starter spun the motor no problem. I then installed the spark plugs, wires and supplied some gas. I turned the key and it would only turn over really slow as if the battery was dead so I changed the battery (using the one from my truck) figuring I drained it turning the engine over with out plugs but I got the same result. The second battery would start my V8 in my Chev though before and after trying the boat boat motor.
Now the way I see it I have one of two issues.
1) Both battery are no good or need charged or dont have the power
2) The starter cant turn the engine under compression and thus I need a new starter.
Now what do guys think may be the reason why it wont turn the engine over under compression but will will if plugs are removed?
