What is the best filler to use on deep scratches
weekendfisher
Hi Guys,
With winter rolling around soon here in Aus i have decided it is about time to get around to stripping out and tidying up my boat and laying down a fresh coat of paint.
What i want is some peoples advice on which is the best filler to use to cover up deep scratches upto about 1 mm deep on the top and inside the boat?
It is a fibre glass open type 15ft runabout
I was going to use a fibreglass filler but i am not sure if that would be best.
It will not be doing anything structural just covering up marks.
I want to get it all nice and smooth before i lay down a coat of paint
i have done one other boat we sanded it back filled with car filler which states it can be used on metal wood and fibreglass hit it with a primer then top coat and it came out well.
But if there is a better way to do it i would like to know
Sorry if it is in the wrong section seemed like the correct area.
Thanks
Bob_VT
Re: What is the best filler to use on deep scratches
I would avoid the automotive filler's....... most actually adsorb water.
Are you going to use paint or gelcoat to repair the finish?
I will move this to the restoration section for you...... there are many methods to fill deep scratches but they all determine what you put over them as a final finish.
weekendfisher
Thanks Bob,
I will be coating it in paint just easier as i can do spray painting at home have done a few cars and 1 boat so now it's my boats turn.
Would the fibre glass filler be a better option ?
Thanks
micks110
I used 3m premium filler with great results. It is easy to sand and recommended for above and below the water. I also used the 3m high strength filler for some of my deeper "valleys" that needed to be built up some, and then I used the premium over that because the high strength is very tough to sand.
Sounds like for your application the 3m premium filler is the way to go.
Good Luck!
weekendfisher
Thanks for the advice
I think i will head down to the local boat shop and see if that have any of the 3M filler there.
Seems a bit pricey to ship it to Aus with the extra dangerous goods fees.
Can't argue with a product recommended for boats would much rather put down something that will stay and not crack of life of in a few months
Cheers
