i recently bought a 57 7.5 evinrude .. i received a rusty tank from another person... has any one cut a pressure tank in half to be cleaned an welded it back together..??? or is it possible to fabricate a new one. using the old hardware..
Is it rusted out or just full of rust? If it has lots of rust in it, there are things you can use to get it out. I used 10-34-0 liquid fertilizer to clean my first tank to bare metal. It worked like a charm. However, you have to have access to the fertilizer. If you don't live close to a plant that makes it, you could also use a product called "Evapo-Rust". I get mine in one gallon jugs at the local hardware store. HEre is a link.
Just used it to clean the splines in the crank of my 65 hp Evinrude so I can put a new driveshaft in it. LEft it overnight and it was clean as a whistle.
