Electronic Ignition 6-cyl, 8-Cyl Prestolite Distributor
Black as
Hi Everyone at Iboats.com
I have a 1988 Bayliner Capri with a 350 chev and 4 barrel carburetor along with a prestolite distributor and came across this item on Ebay http://cgi.ebay.com/ebaymotors/Elec...1089047QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear
Is this conversion any good as its says you also need to change your
Coil, must have 1.5 Ohms or more internal primary resistance. HS15HEC high-energy coil recommended
Is this the best way to go and will it affect my ESA module in operation or is it best to purchase a complete pointless distributor.
Don S
Re: Electronic Ignition 6-cyl, 8-Cyl Prestolite Distributor
Well, it's cheaper than anything else around and sold on ebay. How could you possibly go wrong. :rolleyes:
Black as
Being cheap Don doesn't mean its good, was wondering if anyone's tried this set up before and is it the BEST way to go.
Don S
Guess you miss the sarcastic icon (roll eyes) :rolleyes: :rolleyes:
No, it's NOT the BEST way to go. It has never even been mentioned on this forum before.
Black as
I did see the :rolleyes: but if you don't ask you don't know.
Don, could you then recommend a replacement distributor for me please pointless preferably.
Don S
1988 Bayliner 2250 Capri with 350 chev and Cobra drive
Lucky for me, I can intrpret your signature line. The one word that says the most is the word "Cobra" which indicates you have an OMC setup of eithe a 86 to 89 vintage since you never know what month athe boat was build.
I also know that OMC also used an ESA system that your conversion has to be able to convert to and use, or have a way around it.
Personally, I would go to the Delco EST distributor, and rewire the shift interrupt system to work like Mercruiser. If you don't want to go that way, you end up with either the Pertronix that seems to work with the ESA system, but still uses the mechanical advance.
Black as
Thanks Don, tell me if I'm wrong but I read somewhere here that re-wiring the Mercruiser way can cause issues. And is there a distributor that doesn't use a mechanical advance. Reason being is my current point system set up the mechanical advance works o.k. for a few weeks and then starts sticking.
And I have to say Ive read a lot about the Cobra set up, but touch wood mine runs very nicely.
