97 90 HP Evinrude Primer Solenoid ?
jamiechipper
I am unable cold start without removing hood, turning the red primer solenoid lever to the manual position and pumping the fuel line bulb. I really do not want to pull the hood off everytime I start.
Items to note:
1. I am able to hear an audible sound when I push the primer in and have the key turned
Trouble shooting done this far:
1. There is power to the solenoid coming from the switch
I am unsure what and where to clean. I seen in previous posts, that this maybe a way to fix the problem.
Any thoughts. Thanks in advance.
jamiechipper
Re: 97 90 HP Evinrude Primer Solenoid ?
2. Removed gas line to solenoid to the card
- When in manual position and priming via key, NO gas flows​
- When in auto position and priming via key, NO gas flows​
- When in auto position and priming via gas bulb, NO gas flows​
- When in manual position and priming via gas bulb, gas DOES flows​
This may help answer some questions...
Backlash
Do you hear a "click" or any sound when you activate the solenoid? From all you've said, it sounds like a bad solenoid.
ezeke
The primer solenoid is just a valve; it creates no pressure on the fuel by itself and relies on you to provide the pressure either by squeezing the bulb or by activating the fuel pump while cranking the engine.
If the fuel pump is not working, the primer solenoid will not help.
jamiechipper
The fuel pump seems to be working because the motor runs with no problem once it is warm. I have problems only from a cold start. See first entry. Thanks!
jamiechipper
If I take apart theprimer solenoid, does the gasket need to be replaced?
manual position, pushing key does nothing as valve in wrong location.
bad ground, clogged primer ports, they are very small.
correct, you are not activating the primer, just building pressure.
correct, that is what it is suppose to do.
try having someone pump bulb. key on, pushed in, you should get gas.
disconnecting primer line at top carb, primer fuel line, now turn
push key in and turn to start, you should get pulses of fuel.
Faztbullet
There is also a filter inside primer that may be stopped up due to degraded fuel line or debris over the years.
jamiechipper
Thanks Fellas -
I ended up taking apart the solenoid and cleaning... it wasnt bad, but it has seemed to do the trick.
However, now when in auto position and pumping the gas bulb I am getting a very little gas flow - must have a leak somewhere. Any thoughts... do I need to worry about this?
Thanks!
