Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Just got my first pontoon, had many other boats including sailboats. which brings me to my question--no cleats! How do you attach an anchor to a boat with no cleats. Is there a trick pontooners use?
My toon doesn't have actual cleets, it has the "U" bolts on each corner and one also in the middle(front) for the winch strap. I use two anchors, the front middle and then one on the back right because those are the easiest to get to.
I put a big EYE bolt up forward and dead center to hold my front anchor.It's easy to get to and I always have a line hooked to it just in case. The rear is my problem.I can't get to it. So I have a line hooked to the top rail center back. I always pull it up first before starting the motor.
Many people in Your circumstances just tie the anchor to the play pen rail and hope for mild wind and current conditions. with luck nothing bad will happen. The right way is to install firmly anchored tie points.
