firemedichunter
- Joined
- Apr 22, 2010
- 12
Hi. I am new here but maybe I can get some help....I have a late 70's Johnson 50hp outboard with a powershift II shifter. I just bought it. Both coils and the pack are brand new. I was out lake testing it yesterday and she was running perfectly for several hours. At one point while at full throttle I pulled back on the throttle quite abruptly. The engine immediately quit and now will not start. Carbs are clean and she gets fuel just fine. Plugs look great. Battery is great. It will turn over just fine. When I try to ground the plugs to the head to get an arc I get no spark from either plug or either coil. It appears that I have no spark. All wires have firm connections. I have done lots of reading in the iBoat forums and have heard a lot about a "kill switch." This seems like it might be what's wrong. Where is the kill switch? Some have said it is in the outboard? Is there a "kill" circuit in the shifter itself that, if faulty, could allow the engine to turn over but not provide spark?
Any suggestions would help. Thank you
