catalyst-519
Thread starter- Joined
- Mar 12, 2008
- 64
Hello Gentleman:
Back at this Evinrude 9.9 Model 10655R again after the last 2 summers of changing pretty much every part on the darn thing.
In my journey with this motor (wish I had started with this), I have now learned that the main Crank Case Seal is leaking and pulling air from both sides of the case (more on the right seal). As a result it's interfering with the vacuum system and the carb cannot pull enough gas on low speed to feed the cylinders.
I've been told by a mechanic that some guys have had some luck epoxying over the seal from the outside and avoiding a rebuild of the power head for a couple more summers.
Has anyone had experience with this? Any other solutions than ripping the head apart and replacing the seal?
Thanks for any help you have to offer.
Cheers
519
Cheers
519
