Check the live well switch on your boat, I'll bet you already have a live well timer on it. Push the switch up and it turns on the pump continuously, push the switch to the down position and this will run the timer on the pump, the middle position is off. Most bass boats come set up this way now.
Novice fisherman/boater here. I have a 1997 Wellcraft 160CCF. Not quite sure how to operate or T/S the livewell. Livewell under seat. Switch to livewell but it doesn't fill but manually drains if I add water. Is the pump located in the rear with or adjacent to the bilge pump? Do I need to have the "Acccessory" switch on also? Any suggestions to operate, locate, or troubleshoot would be most appreciated.
