sonoramike
- Joined
- Nov 21, 2005
- 32
Re: (UPDATE)Ahahaahahahahahragarg explative!!!!!! Help!(UPDATE)
ok - now let the hypoticating begin
35-45 wont run in a 4 stroke, but I'd do a non edjumated guess and say that in a 2 stroke it would. and I've personally seen some very hammered reeds - broken in half, split up the middle, etc - in a poorly running motor. either of those
that said, reeds only serve to hold the air/fuel charge in the xfer ports or case until the piston top closes the port off as the piston comes up on compression. they dont come into play on a compression test as it relates to the pressure #'s
orignal poster doesnt note much in the way of clues - when on the muffs did it smoke hard? are the plugs wet or dry? there is no history on how much wear the motor had. did someone before him rebuild it and hog the cylinders out with a hone?
