is it normal to remove the drive shaft by simply pulling???
ncfish
It's a 1979 15hp evinrude, if this is not normal what is the damage???
Fisherball
Re: is it normal to remove the drive shaft by simply pulling???
The shaft from motor into LU? Pulling out of motor, pulling out of LU?
bktheking
It will pull out of the powerhead when you drop the lower unit, it will come out of the lower unit if you pull it out as well.
marinemech1
no the impeller key should hold impeller and drive shaft in housing if it pulls out install water pump repair kit
Wayne
ncfish
thanks bk, thats a big relief, im new to outboards and i have a 6hp johnson that the shaft is tight in there so i thought they where all that way. i had to take the top vent screw are whatever is called out to relieve pressure to get it back in.
bktheking
Never heard of having to do that. Marinemech is right though, water pump has to be off for the shaft to come out.
ncfish
now i see how it stays on there:) yeah i had the pump off when i noticed it would slide, thanks guys.
ncfish
opps, in there...........
samo_ott
Huh? What vent screw?
ncfish
here's a pic. of the screw i was referring to. when i was trying to put back the drive shaft, it was like pumping a bicycle pump, maybe not that much pressure, but it had pressure, and not being familiar with this i didn't want to froce it so i loosened this screw and it took pressure off. http://[URL=http://s809.photobucket.com/albums/zz15/10ring_2010/?action=view&current=101_0691-1.jpg] [/URL]
samo_ott
Ah ok, that could make sense actually. As the pressure will build up when re-inserting the driveshaft. ok.
