Re: 1979 Starcraft Holiday16 closed bow
OK you guys know I can't resist wading into any and all marine wood/foam arguments so here goes.
Dalton, we are here sort of like your cabinet. We make suggestions based upon our experiences and what we've gleaned from others when we asked the question, and you take it all in, look at what you want to accomplish, peek in your wallet, and make the decision.
With that said I'll offer what I think. and this is in no way meant to mean that anyone else here making comments is a moron or doesn't know what they are talking about. I just think sometimes folks make their decisions, and human nature would lead us to beleive it was the best danged decision that could have been made.
First, I went with marine grade 5 ply Douglas Fir plywood in the deck of the liquid limo for a couple reasons. The fir exhibits more resistance to moisture than the danged pine they use in all the other plywoods. Also because it's more dense which makes it a little stronger and again, less suceptable to moisture intrusion.
Secondly, the glue is waterproof in marine grade, not moisture resistant. There is a big difference.
Third, no voids in the inner plies. This makes it stronger and again, gives the water no where to lay around and fester and attack the moisture resistant glue.
Then I applied two coats of epoxy resin to the bottom, and did the same on top with a layer of glass matt. Again for waterproofing, and the matt for added strength.
When I finally get to the wood portion of the mariner, I'll gladly do the same. And I'll use the doug fir marine ply on the transom with at least two coats of epoxy resin on each side. Now maybe that's overkill, but I'm 53 and I don't want to do the same boat twice.
My 44 year old boat had doug fir marine plywood (not resin coated) on the deck and it lasted a heckava long time. I seriously don't think the exterior grade pine would have. I should note that it was severly degraded in areas where moisture collected like around the bottom of the motor box and in the back near the stern.
Now, several of the guys here have taken different paths and no one has come on board and blasted them for it. I guess we all feel like it's your boat and you can do what you want to. But the doug fir marine grade will be the only thing I put in my boat.
If you decide to go that route you can go to Lowes and they will special order it for you but you have to pay shipping.
Additionally, you should consider that most of us have only recently restored a boat and all of them could fall apart in the next 5 years for all we know
