Re: 86 50hp force fuel pump check valve removal
From what my manual says, those other two check valves are not removable and then replaceable. So, if you remove them then you would have to get new ones. I don't know. Mine are all bad, so I am having to get new ones. The way to check them is to "blow" air through them the opposite direction of the way the check function works. If it stops the air they work, if you can get air through both ways, they are bad and will need to be replaced.
