ryanorr280
Thread starter- Joined
- Jun 28, 2007
- 21
i have an 88 OMC Cobra drive 350 motor. having multiple shifting problems...
the one i am working on at the moment is that the ESA does not stumble the engine when engaged. i have looked in my service manual, and see where it shows the wire from the ESA going to the - side of the coil. my question is, is this supposed to send a ground, or a power to the coil? also, mine has an HEI distributor, so i don't have a - terminal. can i route the positive wire to the coil through a relay that would take the power from the coil when the ESA engages? it would cause a stall if it stays engaged to long, but would it allow it to drop into/out of gear easily? thanks in advance
also, is there supposed to be a gasket between the upper/lower units? or is it just a machined surface fit..
