Adding cayenne pepper to bottom paint, YOUR thoughts, work? doesn't work?
chrisg00
I was told adding a small amount of cayenne pepper to bottom paint helps control the growth on the bottom of the boat. i was also told adding a large amount (half cup or so) of cayenne pepper to bottom paint helps control the growth on the bottom of the boat.
I don't want to ruin any botton paint before I put it on.
Any one use this method? Does it work?:confused:
Philster
Re: Adding cayenne pepper to bottom paint, YOUR thoughts, work? doesn't work?
Old fisherman's tale.
Interlux spokesman:
http://www.bwi.org/images/basics.pdf
If Interlux could find a cheap, safe additive for their paints, considering the huge pressure they are under to do so, they'd jump on it. They are stuck with chemicals and pressure from ecologists to find other paint additives.
JoLin
Interlux spokesman:
+1. Waste of time and effort.
Home Cookin'
story is, you're supposed to add it to regular paint. Why add it to bottom paint?
DBreskin
Adding cayenne pepper to your paint will keep squirrels from chewing on your boat.:D
lowkee
As much as the initial thought of it sounds great, you must realize paint is meant to seal things up. This means any additives you put in will be sealed from the elements (and the barnacles). If you can tell me what the color yellow smells like, I'll tell you cayenne pepper will smell exactly the same once added to paint. It may, however, keep anyone from drinking you paint before you get to spray it.
jonesg
Down here on the cape cod "redneck riviera" the locals swear by it, they mix it into cheap paint. Any paint.
Fireman431
If you add cayanne, chili powder, onion powder, and a bit of hamburger, you would have a tasty boat...:D
mike64
I'm pretty sure the only living things capsaicin (the stuff that makes cayenne peppers hot) will deter is mammals. So like DBreskin said, unless you have swimming squirrels attacking your boat, it probably wouldn't do any good.
H20Rat
was about to add that, beat me to it! hot stuff will have zero affect on most marine animals that stick to your boat, they just don't taste it!
Home Cookin'
I sprinkle cayenne pepper on raw (live) oysters and they don't run away screaming. They kinda flinch a little when the lemon juice hits them though.
ajgraz
I wonder if that would keep the sea lions away from my sardines. You might have just given me a million-dollar idea...:D
gstanton
I dunno... deer swim and it keeps deer from eating the landscaping, so it might also keep deer from eating your boat?
