hammbone_merc70
Thread starter- Joined
- Mar 10, 2010
- 6
I've been troubled by this engine for some time now. had the ignition tested and replaced the switch box and stator. The motor would not start. So I read some threads on iboats and tried something I read about disconnecting the yellow/black wire from the micro switch, still the engine did not start. Next I disconnected the yellow/black wire from the switch box and behold the engine fired right up. What does this mean? Faulty micro switch? Also when i went to turn the engine off with the key it kept running, is this normal when the yellow/black wire is diconnected? Any input is greatly appreciated.
