O.K. I have a confusing story however I will do the best I can.
I own a 1993 115 Johnson. While at idle I got a no oil alarm. Turned the motor off and right back on with no alarm. App. 5-6 min latter no oil alarm. Again turn motor off and right back on and no alarm. Ran the boat wot for 15-20 min and got an overheat alarm. Slowed down and check intake and water comming out of the (p) hole was cool, with good water pressure. Ran boat and alarm went off by itself. The next time I took the boat out I premixed the gas just to be safe. I know the VRO is working since I am going through oil. I know the motor is not overheating since I was in clear water, had good water pressure, and the water coming out of the motor was cool. I have run the boat a few times, and now I just have and intermentant over heat alarm that will go off and on with no change in operation. For example I will be running the boat at 4500rpm and the overheat alarm will sound (with good water pressure) and than turn off by itself 1 min later? I thank I just have a bad horn, or a short somewhere any other advice???
