Bought a boat today. Nice restored Grady with a 96 Evinrude 115. It starts, runs decent. Im not all that familiar with 2 strokes so the stutter makes me worry like its missing, a compression test will reveal if thats true or not. However, im getting a overheat buzzer when its warmed up, when it doesnt seem to be overheating. Is there a way i can pull the sensor and clean the contacts? I know its probably a rheostat of some type, where i can get a resistance reading to check it, but what is a normal reading at what temp? I dont have an IR thermometer to get a temp on the heads with me right now. Where is the sensor located and whats it look like?
Also is there a procedure for setting up the throttle cables? When i got it started it was revving at 3/4 rpm at 0 throttle. I played with the free play adjusters to get it down, but im a bike tech by trade so i wanted to know if there was a procedure for setup on them.
Is there anything charictaristcly that goes bad with these motors in general? Anything i need to watch like a hawk?
Just trying to learn a bit about this motor. Ive had sailboats in the past and one non running project boat that went nowhere so im fairly new to powered watercraft.
Also one last question. On the controlls from top to bottom i have the following:
Throttle/trim switch
Fast idle lever
Ignition switch
Funny knob thingy
3 Prong Plug
What does the knob and the 3 prong plug do? The knob turned freely at first in either direction, but as i turned it back and forth (foolishly while trying to get it to start with the fuel line in backward) it got tighter and harder to turn.
Thanks for all the help boaties!
Fast idle lever
Ignition switch
Funny knob thingy
3 Prong Plug
