tried searching couldnt find what i wanted.
Here's what i want to do
FISH FINDER <> EXTENSION LEAD <> QUICK CONNECT <> BATTERY
two Products below are;
battery end:
http://www.amazon.com/dp/B000NCOKZQ/?tag=you
extension:
http://www.amazon.com/Battery-Tende...3?ie=UTF8&s=automotive&qid=1272649696&sr=1-13
I want to leave the terminals on the battery always (inline 3A fuse already on it), then have a quick connect right after it. The extension will plug into here, and lead to my dash where I want my fish finder mounted. The fish finder has 2 wires coming off it, black + red, obviousely.
That 2pin connector has the same 2pin on the other end, where i need to attach to the fish finder.
Is it safe to cut the 2pin end off, and solder the fish finder wires to the appropriate wires on the extension? I see no other way of attaching them together. I don't know much about electronics admittedly, but this seems feasable.
And btw, in the event you attach the two wires reversed and try to power up the unit, it will still be ok right? my unit has rev.polarity protection, just won't turn on - correct?
HUGE THANKS iBoats!
battery end:
extension:
HUGE THANKS iBoats!
