Thermostat replacement.
cbercaw
My 88 force 50hp sometimes over heats as I throttle it up, I have another post about that. I just removed and tested the thermostat and it opens in 135degree water. I ran the engine for a minute or two in a test barrel without the thermostat and it ran a cool 70 degrees, didnt even heat up. Is my thermostat bad?
pnwboat
Re: Thermostat replacement.
It sounds like it may not be opening all the way. May be hanging partially open restricting full flow of water at higher RPM's. I'd replace it.
cbercaw
sounds logical, Ill pick one up this afternoon and report if it worked or not.
cbercaw
Re: Thermostat replacement/ correct thermostat.
What is the correct thermostat to get for my 88 force 50hp? I am pretty sure the manual says 140 degree thermostat. When i ordered one from boats.net, they sent me a 130 degree therm. I cannot remember which one it is exactly because my manual has been destroyed. Thanks..model number 507x8c.
