lyncraft_mechanic
Thread starter- Joined
- Jun 22, 2007
- 233
well about 2 weeks ago i was out fishing when i noticed my 1989, 100HP Johnson outboard started to skip and didnt like to idle down so when i got home i did a spark test and found a weak coil so i replaced it......... after the installation of the new coil i ran the engine on muffs in the yard and the skip did not go away. I did a compreesion test and found that i was in trouble because one cylinder was only about 80psi and all the rest were between 110and 90psi. I pulled the head the next night after work and discovered the bad cylinder was missing a ring and the piston was all chipped up, i was surprised that the cylinders were actually not that bad a shape so i bought a new cylinder hone and have been spending the last two weeks ordering parts for a complete rebuild of the powerhead. Im blaming the ring failure on the not so reliable VRO2 pump and have decided to go with a regular fuel pump and mix my own fuel. now i know where and how to mount the regular fuel pump but my question is do i have to plug off the nipple that ran the vro pump located on the intake directly below the regular fuel pump location?
