After reading a ton of posts I was sold on the CDI brand of replacement parts for our motors. Below is a price list from a distributor with correlating CDI part numbers. Does anyone know of a good place to but this stuff from at a lower price?
Here's the quote you requested. Underline parts, I have in stock and the rest, would take me 5 to 7 business days to get them here to our store. Thank you.
Subject: Parts for 1987 Johnson 110 model # J110TLCUR
2-Power packs: 113-3110..........138.00 ea
1-Timer base: 133-3376..........264.00
4-Ignition coil kit: 183-3737..........39.00 ea
1-Round plug internal engine harness: 413-3036..........185.00
1-Rectifier/Regulator 35amp: 193-5204..........294.00
1-9amp stator: 173-4291 if you can supply 35amp upgrade kit if not then 173-3672..........264.00
2-Tilt/trim relay: 852-9809..........19.00 ea
1-Timing light: 520-ST80..........122.66 or ST82..........350.66
1-Pressure + Vacuum tester: 551-34PV..........284.00
1-Fluke true rms multimeter: 518-115A (should have DVA adapter)..........315.00
