drive shaft housing removal/lower part
gustaria
Drive serial number 0W581501 Model number 5121200TS MERCRUISER ALPHA 1.47:1
need experienced tip on how to seperate unit after bolts and screws removed.
I followed manual step by step. 4 main bolts, trim/anodo bolt and then screw. there was also a bolt towards the aft that I did not see in manual, but I removed it. I do not want to pry and damage. Manual says 'remove and sit aside"
gustaria
Re: drive shaft housing removal/lower part
I found a good thread on this subject. It covered it well, I will check it out now..
