I have this motor and I can't get it to idle. It will rev up great when you can get it started. Starting usually means priming the blue button on the carb a few times. Here is everything I've done to it.
Rebuilt Carb, New champion spark plugs, Check spark (OK), Compression is 110 and 107 top to bottom cly, Flywheel key is alright. New fuel hose, bulb, and fresh non-ethonal gas mixed 50:1.
I have idles the motor up but when i goto throdal it down it doesn't idle down so I have set the idle back down.
Any ideas???
Thanks.
Any ideas???
Thanks.
