6 h.p. Montgomery ward impeller
RiverCaptain
I am trying to take the lower unit off of this motor to get at the impeller. Do i have to pull the power head? or the shift linkage. BEcause i took out the 4 bolts but she still doest come out
M
mrcrabs
Guest
Re: 6 h.p. Montgomery ward impeller
Hey RiverCaptain, what model monkey ward? shift linkage or drive shaft stuck in the power head would be a guess.
RiverCaptain
It is an old 6hp, not sure of the model, but it appears as if the shift linkage is all contained in the lower unit, there is no exposed linkage under the cowl.
M
mrcrabs
Guest
there should be some number on it some place. does the engine have cooling fins like a lawn mower?
