travissowell
Thread starter- Joined
- May 4, 2010
- 7
Hello all, first time on this forum.. well i bought a new to me bass boat with a 1990 175 evinrude that was rnnin badly. I ran a comprssion check and all were pretty good 100,95,95,100,100,65....
the 65 hole had water on the plug so i changed a head gasket, it was clearly blown. now that hole is at 100
So while i was messing with the motor I notice the throttle was only opening the carbs 1/2 way so fixed that. I also notice the wot timing screw was screwed almost all the way in..
I searched every where for the wot timing and came to the conclusion to set it off the starter at 20deg.. I went to the local omc parts/repair house and the mechanic there told me to DO NOT TRUST the timing off the starter method. He told me to run the motor at 3800 rpm and set it at 28deg. while making sure the timing rod is pulling to the stop on its own. so my long winded question is, is 28deg were it needs to be??
I have been told two different things now 20 and 28.. I got the 20 off this forum. AND yes I have ordered a book but i am plannin to go and run it tomorrow and dont want to melt any piston ya know.
Thanks guys
