Hi there.
I bought a boat the other day simply because of the fact that the motor and drive were brand spankin' new ($6000, i saw the repair bills). So basically i got the boat for free. The boat looks pretty good also, don't get me wrong, but when i opened the storage compartment in the center of the boat used for storing the anchor and anchor line) i noticed a piece of fiberglass cracked right in the center of the storage, exposing the plywood underneath. When i pushed on the wood with my finger, it went right thru (oops). I started to remove the cracked fiberglass and i also took out a piece of plywood, all rotten and smelly, about 16x32 inches (came out in a million pieces, mind you). Under the plywood was a hollow opening with a couple of tubes at both ends (drainage from adjacent compartments?) and then the bottom of the boat. Can i just leave the opening like that, will it affect the structure of the hull, or do i have to install new plywood and fiberglass it over? All the other floors are solid, on deck and in the cuddy.
Any input will be appreciated.
Tks much,
L.
Tks much,
L.
