Xesvuli420
Thread starter- Joined
- Sep 20, 2009
- 144
Ok I've lost reverse. When I move the throttle back it just clicks real fast but never engages.
If I go back to the engine, I found a cable that has a little rubber thing that is held in the linkage with a cotter pin.
If I pull that rubber thing out, it can be adjusted by spinning it around on the cable. By adjusting it this way I can get my reverse back, BUT once I adjust it to get reverse engaged, I don't have forward any more.
There is no happy medium, its one or the other.
Also sometimes when I go forward, the boat will engage and start moving, and after about 10 seconds traveling, I will hear a big thud, and the boat "kicks". To me it seems like its engaging enough to turn the prop, but not fully and then after a few seconds of forward, it kicks itself in.
These problems all seem to be related because they all started to happen at the same time.
Suggestions?
Thanks guys!
Suggestions?
Thanks guys!
