jserb
Thread starter- Joined
- Nov 29, 2005
- 406
Re: Michigan to chicago trip help!
Whoaaaaaa,
someone had their coffee way strong.......
THANKFULLY I am an avid boater, during the winter months i enjoy reading and learning more about boating. Because of this, i know how to use a chart and dead reckon, i understand all nav aids and buoys, I know how to use a compass and the sun for reference, i also know what lights to look for while underway at night. None of the above will be an issue
Regarding the magnetic variation, yes all charts tell the user how to compensate for this. To say its necessary to check a paper chart every 15 mins on this kind of trip is overkill.
Factors that need to be considered, 1. the trip will not be taken at night or during a storm, 2. 20 miles off the coast of Michigan you can see Chicago. 3, as long as you are heading West you will find Chicago.
I appreciate all input, however lets be honest and call this what it is. Personaly, sounds like your trying to mislead and scare a highly educated boater. I find sometimes on these threads people give negative advice and at times try to hinder the objectives of another boater.
I couldn't agree more. If you aren't comfortable navigating using a chart, compass, and timepiece I would suggest you not make this crossing in one shot. Assume your GPS will fail. You cannot count on it as a primary navigational tool. Even with GPS you should be plotting your position on the paper chart every 15min. This way if you have an electronics failure you can easily dead reckon your way across with a fair degree of accuracy. The approach into Chicago can be VERY confusing. The ability to confidently read a chart is a necessity for this trip. I would not venture out at night on the Chicago waterfront unless you have someone with you who has made the approach at night before or you are very confident in your abilities. The background lights of the city make picking out nav aids very challenging. Several boats every year run up on the various breakwall rocks on that waterfront. Don't be one of them. Inspect your boat and bring tools and spares. I've made some crazy repairs offshore over the years and while they're fun to talk about now, they weren't real fun when it was looking like our number was up.
You also need a firm grasp on Inland Waterway/COLREGs and if you will be out at night you need to understand navigational lighting. If you can't tell how to identify things such as a tug with tow by lights alone you shouldn't be out there at night. Good way to get killed. I came on deck at night during a Mackinac race to find that the helmsman on watch had us set to pass in between a tug with tow separated by about 1000ft of cable. That could have easily been curtains for all 8 of us.The traffic around Lower Huron, Detroit, Erie is kiddie play time compared to this section of water.
14927, 14928, 14930, and 14901 are the charts you need. Your compass (which hopefully is high quality) will be a few degrees off over there (assuming you calibrated it for your local pond.) Make sure you understand and know how to account for magnetic deviation. You will quickly leave cell phone range. Make sure your VHF is working properly and you understand how to properly communicate on it. You should know how to properly hail bridge/lock operators and other vessels. You should know the difference between Securite, Pan Pan, and Mayday and when to use each. The CG wants Lat/Lon, degrees, and speed in knots, # of persons on board and # and type of flotation.. They don't want "Um, I'm in a white boat doin' 30mph headin' toward that orange building." Review your required safety equipment and make sure all of it is up to date. Go over all of your light/sound/flotation/safety and make sure it meets current regs and nothing is expired. You will be a target for law enforcement sporting MI tags. Since you have a friend with Harbor Master duties you can lean on that person for tips on how to deal with the nightmare that is Westrec. They should be able to fill you in on all the details you'll need to know about Chicago harbor system.
If this all sounds like overkill then you've never been in the middle of one of these ponds with the S*&% hitting the fan.
Whoaaaaaa,
