Build up of something (salt or scale maybe) on bare aluminum parts after only 2 trips
sbklf
Probably 95% of the rust on the troll motor and all of the white film on the motor and jack plate occured after just two fishing trips (in salt water). It appears to be plating and I suspect it is caused by an electrical condition. Anything that was bare aluminum in contact with the water got plated and the ferrous parts on the trolling motor rusted. It is a 24 volt troll motor and I noticed it was shocking me towards the end of our second trip and is why I suspect this. The film is very tough. I tasted of it and it does not really taste like salt. I am mostly concerned about this film in the water jacket. I had already planned to take it to Ronnies in Port Oconner to have it de-scaled. I hope his process will remove this stuff. Any one else ever dealt with this situation? Any thoughts on the probable cause?
jspano
Re: Build up of something (salt or scale maybe) on bare aluminum parts after only 2 t
looks like some kind of electrolisis, do you have any zinc tabs on the motors?
they usually bolt on the outboard and some have a zinc washer for trolling mtrs. make sure all the grounds are good. all systems should have a good ground wire, not just metal contact to something already grounded. it's got to be something really obvious to do that so fast.
you might want to post in another forum maybe marine electronics or motors
good luck
if you find what it is from another forum pm(private msg) me, i'ld like to know
Bob_VT
Are any of your electrical items grounded to the aluminum hull??? You need to make sure you are not using the hull as a ground for ANYTHING and run a separate ground circuit from the negative on the battery.
Make sure the simplest things like a bulb or an extra ground for a gauge....
jspano
i found this it, seems like a good read
posted by jimbc
Corrosion
What is it?
Corrosion, partial or complete wearing away, dissolving, or softening of any substance by chemical or electrochemical reaction with its environment. The term corrosion specifically applies to the gradual action of natural agents, such as air or salt water, on metals.
If metal can carrode around salt water d oes it make sense to use aluminum boats in a salt water environment? Yes. Aluminum boats in general and Duroboats in particular offer great performance, ease of maintenance and economy. The need to operate in salt water should not deny you thoose benefits, but you must be smart about it.
It is good to be concerned and keep an eye on corrosion.. All metal boats are potential candidates for galvanic corrossion. We use high quality aluminum, which is corrosion resistant but not corrosion proof.
Customers should protect against corrosion the best they can and be vigilant in looking for it. There are many variables. In some waters you could leave the boat for a significant time without any ill effect. . In others damage can begin in a short time.
The variables include; salinity of the water, temperature, organic material in the water, electrical activity nearby, presence of other metals, etc. Commercial harbors can be worse for electric activity than remote harbors. There is no way to know what your boat will experience without observation. Protective coatings can help prevent the build up of organic material on your hull. Organic material can be an aid to corrossion. . If you use a protective bottm paint make sure it is made for use with aluminum. It must not be based on a dissimilar metal. copper is particularly problematic. Side note: Copper pennies, copper shell casings, heavy copper wire used as fish clubs have all been known to be starting points for corrossion if left in the bottom of an aluminum boat.
Watch for corrosion near bolt holes, chipped paint, behind peeling paint and any place the aluminum has been scratched or dented. Edges, cracks places that trap salt water are more susceptible than flat surfaces. Avoid build up of organic material, plant growth, algae, barnacles etc. Organisms create conditions that make the aluminum more susceptible to corrosion.
Inspect the keel, chine extrusions and corner castings regularly. If they have been dented or scratched on rocks or beaches they may provide a starting point for electrolysis.
Except for sacrificial anodes, don't mount any metal to the hull other than aluminum or high quality stainless steel. If you use fasteners they should be plastic or stainless, not zinc, brass, copper or iron based.. Inside the boat, don't let any metal sit in the same spot in the bilge for long. Lead sinkers, fish hooks as mentioned earlier copper even a penny sitting in one spot can be a starting point for electrolysis.
Isolate the hull from electrical current. Make sure your battery is grounded to your motor. . Don't ground electrical devices to the aluminum hull.
If you are going to moor the boat even with a protective coating it should be inspected often and the hull cleaned often. Don't let salt residue build up on any surfaces. If you see corrosion arrest it immediately before small damage becomes big damage.
Cathodic protection in the form of sacrificial anodes is required if you will moor your boat in saltwater.
What is that?
Cathodic protection prevents corrosion.
Your boat if not protected is susceptible to electrochemical corrosion.
Galvanic Corrosion--occurs when different metals with different galvanic voltages are electrically connected and wetted by water. Stray Current Corrosion--occurs when submerged metals are asubjected to an electrical current that has strayed from an electrical circuit powered by a battery, generator or dock power. It is the result of an electrical fault.
Metals have different levels of nobility depending on how readily they give up their mass when in a hostile environment.
When corrosion is at work metal actually leaves the least noble metal in any circuit and deposits itself on the most noble metal. Aluminmum is low on the nobility tables so it will give itself up if it is in a salt solution near a more noble metal and there is electrical activity (natural or man made) present.
Cathodic protection is supplied by the use of sacrificial anodes. Fortunately for aluminum there are metals that are even less noble. They include magnesium, zinc and some aluminum, zinc alloys.
These metals can be made in to sacrificial anodes. The anodes when attached directly to an unpainted area of an aluminum hull will protect any part of the hull that is not electrically isolated form the anode.
Which one is best? for our boats probably an aluminum. zinc allow. Magnesium is very active in salt water and is sometimes used for fresh water applications. Zinc works well but can oxidize over when exposed to air. This means if zincs are not cleaned when a boat has been out of the salt and the boat is returned to the salt the oxidized coating will protect the zinc and it will not function as a sacrificial anode.
Some aluminum , zinc alloys will function well and not oxidize over so they are better for boats that may be periodically out of the salt water.
Anodes do not last forever. Somewhere after 1/3 to 1/2 of the metal in an anode has disappeared it is time to replace it. Some anodes will have built in warning devices that indicate when replacement is necessary.
__________________
