vrundquist
Thread starter- Joined
- May 8, 2010
- 28
Hello,
I have a 1990's 225 gear case. the drive shaft snapped off at the pinion bearing today. I have gotten the gearcase taken apart all the way to the point where you remove the pinion gear. I cannot remove the nut, due to the drive shaft geing broken off. I can pull the prop shaft out slightly and push down on it, but I still do not have enough clearance to remove the pinion and small piece of shaft attached to it.
Any suggestions would be greatly appreciated.
Thanks,
Victor
Thanks,
Victor
