MakO17 90 EvinrudE
Thread starter- Joined
- May 9, 2010
- 28
hey guys im new to the forum hoping to find some helpful input on my situation. okay lets go back to summer of 2009 everything on my 1996 evinrude v4 90hp was running great. its on a 1990 mako 17 center console v hull. the motor ran great rarely gave me trouble. this past winter i didnt use it much it sat for 6 months i would say, about 2 months ago i turned it on it cranked right up so i decided to take it to the everglades. it ran for about 3 miles great i slowed down and then eventually went to start taking off again... and i very loudlyreved up and spun the prop. i had to replace the prop same size of 14 17 i believe, and i also had to replace 2 carb float chamber covers for they were leaking gas from a little side hole. i thought this would be it so i took it out to the glades again.. and this time when i would start it, it ran great idled fine reved up in neutral fine i went into gear and began idling up the lake, when i gave it throttle down, it began to rumble in the water at low rpms and the boat would not move much faster then idle speed. im hoping i can get some advice from you guys it would be greatly appreciated. ive read som other threads of similar symptoms and i saw suggestions such as compressions tests check and change spark plugs, clean out all carbs, so i am goingto trry these things. anything other advice will be greatly appreciated. thank you
