1994 OMC 115 TurboJet thumping and stalling at low RPM
ScituJet
Hello all,
I picked up a 1994 15' Rage with a 115 OMC TurboJet last fall. The previous owner had disconneted the warning horns and it overheated badly. Sand in all the wrong places and two melted cylinders. Over the winter we rebuilt the engine, installed the VRO fuel system, replaced the powerpack, and added a sea strainer. All should be good and ready to go - except its running like 'doodie'.
At low RPMs (1500 or less) there is a non-rythmic thumping sound or 'back-kicking' which leads to a stall. Runs and sounds great at 2500 RPMs or higher.
We disassembled everything trying to find a mistake and can't find the cause - very frustrated at this point. This thing should run like new and instead has us banging our heads against a wall. Any suggestions on what we might look at next would be appreciated.
Thank you
ScituJet
What - am I canadian? Re: 1994 OMC 115 TurboJet thumping and stalling at low RPM
Help.
ScituJet
Thank you ezeke - checking now and will provide update.
ScituJet
Success!
Timing base/trigger was malfunctioning. With no other ideas of what was going wrong and getting tired of taking everything apart and putting it back together without a solution - went ahead and replaced the base and the thing is running great. Coils must have fused together when it overheated. What a relief and I can't wait to hit the water!
Thanks for the advice.
:D
SKEETR
I have been told that the low rpm backlash thumping sound was pretty normal with the turbojets. Are you saying that you replaced the timer base and it is completely gone now??? Smooth idle at say 1000 rpm even??? Really???:)
