1995 Mercury 9.9 water pump problem
tomnagle
I have a 1995 Mercury outboard long shaft electric 9.9 HP and I have been trying to replace the impeller. It runs well until recently.
I put the motor in neutral shift and took off the three bolts but the lower unit only dops down about three inches. That's it. I understood from the parts place that the whole lower unit is supposed to drop down and out. . I have pushed and pulled but the unit will not drop any further. I tried a screw driver but with no luck. Decided a hammer might cause serious damage.
What am I doing wrong? I am feeling confused. Help!
shimano
Re: 1995 Mercury 9.9 water pump problem
You have to remove the shift rod and it should come off easy.
tomnagle
Thank you much.
I now have gotten the lower unit off. My biggest problem at the moment is putting the "key" into the new impeller. Do I hammer it in? It is really a very tight fit. I tried using thin-nosed pliers and pushing the key into the impeller but the key keeps jumping off the pliers and then I have to go search for it. Any suggestions?
My thanks again for your helpfulness and kindness.
Tom Nagle
shimano
You have to put the key on the shaft and slide the impeller down over it.You can use a little grease to keep the key there while you push the impeller over it.
tomnagle
Shimano,
Thanks. I will give your suggestion a try this evening. You have beeen a great help.
Tom Nagle
