9.8 mercury help...
yang81
got a 9.8 merc...this is the problem...on the water ran fine then it died on me while in forward...primed the bulb and started it again ran at half power...then died again...i'm a first time boat owner so i am stuck...i dont want to take it in the shop if i can fix myself...please help this newbie...thanks
yang81
Re: 9.8 mercury help...
Someone please help...surely someone can
shimano
Check if you have spark on both plugs.
dingdongs
have u a vaccuum in fuel tank if so undo tap in cap.also is the fuel new or any crap in tank.maybe check floatbowl of carb too.
sschefer
make sure the vent is open on the fuel tank.
Jacket4life
Yeah, I did this this year the first time out. Forgot to open the vent after putting the tank on the boat. Felt like a dummy. BUT, at least I haven't joined the no plug club yet!
yang81
that still doesnt solve my running at half power...does it...thx
Jacket4life
If you have your tank vent closed that is exactly the symptoms you will see. You can force fuel into the carbs, then the motor will start and run briefly and die. esp as you try to open the throttle because it is trying to draw more fuel but you have it vapor locked. Simple thing to check, did you look to see if your vent was open on your fuel tank?
yang81
my tank is plastic and seems worn down...maybe i'll replace it and see if that cures the problem...its just that earlier that day it was running fine then suddenly about an hour into trolling it happens...it also clicks right before it dies...thanks in advance.
ENSIGN
Sounds like you got some dirt or old primer bulb up in the carb and the fuel system needs a good cleaning
yang81
Well...i replaced the fuel tank and still have the same problem....i also noticed that the lower unit gets really hot and theres no water coming out of the place where it usually shoots out(sorry i dont know what thats called)...lost and confused
Jacket4life
Uh-oh.
Wish you had mentioned this at the beginning, but one of us should have asked too....
Your motor is overheating. Your impeller is probably no good at all.
Let's start over. Where do you usually run this engine?
Are you aware that you CANNOT run outboard motors "dry", that is without being in water above the intakes on the foot by the propeller or having a source of water introduced, like with tuning "muffs" that hook onto your garden hose?
IF the answer to these questions is no, we need to back WAY up.
Answer these and we'll see if everyone on here can't get you going. DO NOT RUN YOUR MOTOR AGAIN UNTIL YOU GET MORE ADVICE. If it has over heated even once, you could already have MAJOR engine damage. Ypu may be ucky, but don't run it again until we get you going in the right direction or it will soon be complete toast.
yang81
it happened to me on the water and i do believe there was enough water present while it died there(was on the river)...although, i did some testing today with the new tank in a 50 gal. drum of water...i did make sure there was enough water also...i run this on a fresh water river...
yang81
Realized today that when i run the outboard in forward, it heats up then dies in about 2 minutes...what do i do!
