Re: Motor Won't Go over 1100 rpm
Don't just throw a new tach on it, find out what the problem is. It could be a cracked coil tower, and the high voltage is arching to the - terminal of the coil, causing the tach to read wrong. It would also cause your engine to miss, which would also cause your lack of power> could all be due to 1 bad plug wire or spark plug.
