pulling risers w/o water in heads
fishingman220
i need to pull my risers on my closed cooling(anitfreeze in manifolds, water in riser) 5.7 due to a leaky 90 deg. fitting. my question is how do i pull without getting water down in the manifold and then into the head and cylinder?
Black as
Re: pulling risers w/o water in heads
Not sure with your engine but check the underside of your manifolds at the rear of the engine, do you have a plug or hose attached, if so drain it from there or any part lower than the manifold
Bt Doctur
You need to drain the A/F in that manifold ,then remove the 2 brass drain plugs in the riser.
shouldnt have more than a drop or two getting loose
fishingman220
and yes i know the drains in the manifolds, i understand that part, i just dont want alot of raw water to fill the head
Rat Capri
pull the lower hose off the water pump, that will drain the block down to the water pump inlet/outlets
fishingman220
ok i lied, it does have one plug on each but on the top.
fishingman220
nope, nthing around the bottom, i will take pictures this afternoon and post them
