AlwaysFishn'
Thread starter- Joined
- Mar 5, 2010
- 30
2004 DF115 Suzuki- Still getting water in oil only under a load
Started out having water in oil unfortunately end result was white foam. I bought a Full gasket set - proceeded to go after my head gasket which wasn't it. I followed the service manual to fit back together torquing sequence.(Maybe it needs to be redone/)I have no liquid in cylinders. I found an area around my engine holder exhaust that showed to have a blow by leak it appeared to be burnt marks I've check for flatness with a straight edge it doesn't appear to be warped (I've been through 3 crushed gaskets thinking that was the problem)(so I put a thin layer of the "Right Stuff" gasket maker under gasket and on top of crushed gasket in between the engine holder and power head in last resort as going through 3 gaskets previous. Are these blocks or heads known to crack is there a way to check for cracks or am I not looking at this right? I notice that there are many large screws or inspection screws but I don't know what to look for using them. The motor runs great/ idles great/ sounds good/ I go to lake to test run put it under a load and ten minutes later the oil is white errrrr. I realize the best thing is to bring it in but for the finance situation I have---I have a few months to figure it out on my own or with your help. If I'm not explaining myself correctly ask me the question I will try to answer to figure this thing out.
