Trim stuck up
joeturse
When I trim my 150 all the way up,it seems to get stuck.After trying a few times it will let loose and come down.
Anyone have this problem?
RRitt
Re: Trim stuck up
mechanical stick is usually caused by wallowing of head/top assy allowing piston to jam crooked. motor not running can be either relays, brushes, or wiring.
joeturse
Re: Trim stuck up
Tilt motor runs,but it takes a few tries to get it to work.Could having the motor tilted all the way up have anything to do with it?
Forgot to mention it is a 2001 Johnson.
RRitt
Re: Trim stuck up
position of engine only affects motor if there is loose wiring. Loose and worn wiring is always first thing to look for with intermittent failures.
ezeke
Re: Trim stuck up
Could be that the tilt limit switch is sticking.
